А кто-нить считал ресурс капов КВИ?
ИМО они не протянут больше получаса работы в тесле. На половине номинальной напруги. Цитата из документацит к импульсным максвеллам: "For instance, a Maxwell type 31162, is rated at 100,000 shots at 75 kV with 20% VR. (20% VR is Q = 1.4) Now, we want to know the life in a Tesla coil at 90% reversal (a Q of 15) and a peak voltage of 42 kV. Applying the above formula: Lx = 1E5 * ( 1.4/15)^1.6 * (75/42)^7.5 = 1E5 * .0225 * 77.37 = 1.74E5 shots. reducing the voltage to 30 kV would increase the life by (42/30)^7.5 or 12.5 times. If this were in a Tesla coil at 120 bps, at 42 kV, it would survive (90% probability) about 24 minutes of run time. Reducing the voltage to 30 kV would increase the life to 300 minutes, or 5 hours. Reducing the peak voltage to 20 kV is even more effective, increasing the life to 100 hours. Killing the Q down to 10 would increase the life by (15/10)^1.6 some 90 percent. Capacitors rated for high repetition rates are necessarily overdesigned. Comparing two units from Maxwell Labs: * 1.0 uF 40 kV 1pps 1E5 shots 2.3x5.9x27.8 inches * 0.1 uF 40 kV 1000 pps 1E8 shots 2.3x5.9x14.8 inches If the high reprate capacitor (with a 1000 times the life) were scaled to the capacity of the low rep rate unit, it would be about 5 times the size of the low rep rate unit. A life factor of 1000 can be achieved by increasing the rated voltage by about 2.5 times. This would require about 6.25 times the total capacitance arranged in a series parallel configuration, which correlates well with the physical size increase factor of 5." Вобщем, скажу я вам, детишки, что батарея КВИшек на 24кВ будет работать нормально только на 8-9 кВ. А потом закономерно сгорит через несколько часов. А сколько протянут мои ЭЛКОкапы судить не берусь. Они ваще уникальные и никто их не тестировал И завод тот больше не существует походу...
Так что, если сгорят буду как Dест заказывать капы из пендосии... Добавлено: Sat Mar 17, 2007 12:29 am |
Я тож нипонял... Добавлено: Sat Mar 17, 2007 12:56 am |
Параметры импульсного режима КВИ-1 Частота следования импульсов, Гц ≤10 000 Длительность импульса, мкс 0,04÷1 000 КВИ-2, КВИ-3 Частота следования импульсов, Гц ≤5 000 Длительность импульса, мкс 0,01÷1 000 Гарантийная наработка 25 000 ч Гарантийный срок xранения 12 лет Добавлено: Sat Mar 17, 2007 1:30 am |
Я вот нихуя не понял, как и куда этот разрядник ставить? Может кто нить покажет или расскажет? Добавлено: Sat Mar 17, 2007 3:30 am |
Юрий правильно привел цыфирь. Максвелловские может и сдохнут, однако КВИшки должны нормально отпахать свои честные 25000часов. Кстати поэтому КВИшки и стоят на порядки дороже всего остального (я не о ценах на советские еще... которые на складах валялись. я о новых ценах, а они как вы знаете....) Добавлено: Sat Mar 17, 2007 6:21 am |
Рост писал(а): Я вот нихуя не понял, как и куда этот разрядник ставить? Может кто нить покажет или расскажет?Защитный? Ны дык параллельно батареи кондров. Добавлено: Sat Mar 17, 2007 7:52 am |
Ясно, спасибо. Добавлено: Sat Mar 17, 2007 8:34 am |
Но ведь в Тесле КВИ работают не в импульсном режиме. Добавлено: Sat Mar 17, 2007 10:18 am |
AlexDark писал(а): Но ведь в Тесле КВИ работают не в импульсном режиме. Значит прослужат ещё дольше , ибо мягче режим работы. А 25000часов это очень много.Если такая гарантия , то срок службы ещё раза в 4 дольше как минимум. Ведь у большинства ламп срок наработки на отказ 1000часов , а пашут они десятилетиями!!!! Добавлено: Sat Mar 17, 2007 10:23 am |
а в каком режиме они работают??? по моему в импульсном. Добавлено: Sat Mar 17, 2007 10:30 am |
В искровой - в импульсном , а в DRSSTC и VTTC в обычном. Добавлено: Sat Mar 17, 2007 10:43 am |
ну так вроде бы речь и шла про искровую... Добавлено: Sat Mar 17, 2007 10:47 am |
Я б не назвал режим работы в колебательном контуре с огромными пиковыми мощностями легким. В моем справочнике(электрические конденсаторы и конденсаторные установки под ред. Кучинского, с 407) такие данные: Параметры допустимых режимов. Для КВИ-1 tи=0.04-1000мкс; fп-10^4Гц, импульсы двуполярные. Для КВИ-2, КВИ-3 tи=0.1-1000мкс, fп=5*10^3Гц, импульсы однополярные. При tр(рабочем времени)=1ч или одиночных импульсах Uмд(наиб. допуст. амплитуда имп. напряжения) конденсаторов КВИ-2 при Сном=100пф может быть увеличено с 8 до 10Кв, допускается работа при U0д(допустимое пост. напр)=0.75Uном m(номин. импульсн. напряжение). Показатели надежности-tмин=5000ч, fехр=12 лет. Добавлено: Sat Mar 17, 2007 10:54 am |
Если в СГТЦ капы работают в импульсном режиме, то и пленочные, и бумажно фольговые тож пойдут, потому что подавляющее большинство импульсных капов именно такие. Но они не подходят, след. там не импульсный режим. Имо, импульсный режим-это маркс. Добавлено: Sat Mar 17, 2007 10:56 am |
сгтс импульсная! а бумага и пленка не подходит потаму что там еще и вч есть, которое приводит к нагреву изолятора, а в марксе вч нету. да и если бы маркс давал 10-20 импульсов в секунду, то наверное тоже бы грелся. Добавлено: Sat Mar 17, 2007 11:15 am |
Просто для КВИ ВЧ параметры вообще не нормируются и в справочнике не приведены. В передатчиках их юзают, но, как минимум с пятикратным запасом по напряжению. Добавлено: Sat Mar 17, 2007 11:20 am |
Господа, вот к чему стремиться надо! http://hot-streamer.com/ross/Biggg/biggg.htm и пара фотог: http://hot-streamer.com/ross/Biggg/P1010003.jpg http://hot-streamer.com/ross/Biggg/P1010005.jpg Питалово - от двух спаренных невъебенных свиней 2 Упырь: слабО такую собрать? Добавлено: Sun May 20, 2007 8:42 pm |
C таким питаловом эта тесла - отсос полный и собрать абсолютно не слабо - дай только питалово и денег. Добавлено: Sun May 20, 2007 11:28 pm |
Полнейшая хуйнища. Тесла, которая дает чуть больше своей длины? Кал. Добавлено: Mon May 21, 2007 9:46 am |
Тебе лехко говорить ![]() Добавлено: Mon May 21, 2007 2:44 pm |
Между прочим ничего особенного в моей катушке нету. Просто нормальная ММС и Гап. А вторичка, кстати, вообще говно. Непропитанная, и побитая вся..... Добавлено: Mon May 21, 2007 2:49 pm |
Упырь,смотри лс Добавлено: Mon May 21, 2007 3:05 pm |
Ну дык ММС этафсёъ!!! Добавлено: Mon May 21, 2007 3:07 pm |
Точнее сказать весь первичный контур это все ![]() Добавлено: Mon May 21, 2007 5:16 pm |
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?22493 http://hvguy.4hv.org/16in%20DRSSTC/ http://hvguy.4hv.org/16in%20DRSSTC/16in%20first%20run.wmv (1.1М) Вот это да причем заметьте это не СГ а дриссетц!
также на главной странице этого hvguy есть 15квт стгц, 5 метров снимает... почти 2 длины вторички Добавлено: Mon May 21, 2007 5:22 pm |
